cool need to know info! a quick fix for a radiator leak!
Old Oct 29, 2004 | 11:51 AM
1ShotScott's Avatar
Default cool need to know info! a quick fix for a radeator leak!
I was watching mythbusters the other day. it was a new eposode of car myths. they found out that if you have a hole in your radiator that you can crack an egg in your radator fluid and it would close up the hole, this is for only anit-freez not oil!!!! they said that it is not a perminant solution, but it should hold it for a while, and it sould not do any thing to your engine! cool huh!
Old Oct 29, 2004 | 02:11 PM
yamahawarriormods's Avatar
Default cool need to know info! a quick fix for a radiator leak!
sweat
Old Oct 29, 2004 | 05:35 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
it works because that when you try to beat eggs if you notice it's so hard to breakup the egg it holds together so well and because of that and of the inside of the radiator and channels are smooth enoghu that when it hits the crack it sticks somewhat and because the egg stays together it will hold the leak for a lil while
Old Oct 29, 2004 | 05:36 PM
Speedy2222's Avatar
IF that is true it SHOULD work... besure that you flush the radiator when you fix it (which should happen neways)
Old Oct 29, 2004 | 05:41 PM
Jibrille's Avatar
We use pepper for our radiator leaks, it has never gave up problems, and can be flush out when you fix the rad.
Old Oct 29, 2004 | 05:45 PM
Speedy2222's Avatar
jib we talkin about coarse or fine pepper?
Old Oct 29, 2004 | 05:48 PM
Jibrille's Avatar
Um, fine I guess. It is stuff you can buy bulk, and you don't have to grind down.
You don't have to pour a lot in just probably a tea spoon for a quad radiator, but say like a handful for a truck or so..
Old Oct 29, 2004 | 05:49 PM
Predator19's Avatar
It had better work....i saw it on MacGyver once.
Old Oct 29, 2004 | 07:41 PM
1ShotScott's Avatar
yah I thought it was real cool when I saw it.
Cummins Driver
Sep 11, 2019 01:22 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
ltrmc02
Jul 22, 2015 04:50 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
