lt 80 carb hook up ?
Old Oct 30, 2004 | 05:55 PM
chris6's Avatar
Default lt 80 carb hook up ?
There are 3 ports on the right side of the carb.1 is for the gas feed (brass on the bottem), 2 is vac turn on for fuel(wich one of the top two ?), what is the third one for(top hose on the oil tank)?
Old Oct 31, 2004 | 05:27 PM
chris6's Avatar
one more question how do i hook up the oil injector hoses where do they go. ( incase anyone is wondering I got this quad in a couple of boxes) any help is would be great.
Old Oct 31, 2004 | 08:48 PM
ddtia's Avatar
the one with the brass end on the right side is for the oil injector line.
the lower and middle one on the left is to the fuel bowl from the petcock, the forward one I think is a vent line, I could not see were it went. the back one on he left is suppose to be the vacuum line but I cant get mine to work. I capped it and used a banshee petcock (no vacuum).
hope that helps
Old Oct 31, 2004 | 09:09 PM
chris6's Avatar
thanks for the reply ddtia
Old Nov 1, 2004 | 04:48 PM
LT80's Avatar
LT80 Expert
The lil tiny brass fitting on the LEFT side is the oil injection.
On the RIGHT side there are 3 holes. The big brass is the fuel the front upper hole is the vent, rear upper is the vaccum to the petcock.
Old Nov 1, 2004 | 05:02 PM
chris6's Avatar
thanks lt 80 that works for me.
Old Nov 2, 2004 | 08:41 AM
Hawkdriver's Avatar
The rear upper 'vacum vent to the petcock' - is there supposed to be a hose attached to this? Mine won't start, and I think it's the carb somehow (floods out). I have the fuel, oil, and other cables hooked up correctly. It's just the top aluminum nipple coming off the part that attaches the carb to the reed valves.
Old Nov 2, 2004 | 10:49 AM
LT80's Avatar
LT80 Expert
Yes there is supposed to be a hose on there. It goes to the petcock.
Old Nov 2, 2004 | 09:24 PM
Hawkdriver's Avatar
My appologies - I forgot to mention that I'm an idiot. What is a petcock? Where is that on the motorcycle?
Again - thanks for the help..
Old Nov 2, 2004 | 11:01 PM
1fastpolaris's Avatar
The petcock is the on and off valve on your gas tank
GregM
Mar 6, 2018 06:53 AM
TheHood
Aug 8, 2015 05:49 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
