350x sprocket
Old Nov 1, 2004 | 12:43 AM
MY86ATC350X's Avatar
Default 350x sprocket
where can i get a rear sprocket for my 350x so i can make it go faster, i think i need it smaller on the rear. an aftermarket one.
Old Nov 2, 2004 | 04:07 AM
ThrashAndCrash's Avatar
Yes, smaller makes it go faster (top end). You can pick one up at any local motorcycle shop for pretty cheap. If you are looking for a high dollar one the I can give you a few links.
Old Nov 2, 2004 | 12:40 PM
how many tooth sprocket do u have? im interested? and yea give me some links to check them out.
Old Nov 2, 2004 | 02:40 PM
I have a 40T rear with 22" tires and it works GREAT for trail riding, but for flat fast rides the sprocket is too big. I top out around 66MPH.
Old Nov 2, 2004 | 02:56 PM
Sprocket Specialists Has a ton of choices
After doing some looking for you, that is prob the best place for an aftermarket. Stock ones I can get for about $15
You can get the rear sprocket in a range from 34-74 teeth!!!!!!!!
If you want to change gearing you can also play with the front sprocket, they are WAY cheaper and easier to get a cheap one. As a suggestion....Get the cheapest sprocket you can find while you are playing with gearing, then when you find the correct combo buy the good stuff.
{on the front sprocket BIGGER is more top end)
Old Nov 2, 2004 | 11:08 PM
i think on the front its a 15-16 tooth but i want more speed, on the rear do i need more tooths or less. i think its less.
Old Nov 3, 2004 | 03:24 AM
if you have a 15 or 16 tooth front, THAT is you speed prob. Check it and I would go to around a 12 or 13
Old Nov 3, 2004 | 01:39 PM
yea but when i had my 13 tooth on the front it would run really slow, shift gears rapidly, i checked and its a 15 tooth, but if i add smaller it would run slower, i want more speed, i checked everything my final ratio, gear ratios, tire size, and max rpms,and compared, my speed will run at 72mph. i at least want to hit 80. so bigger or smaller in the rear?
Old Nov 3, 2004 | 01:59 PM
I'm sorry ...MY last post was backwards............15 tooth is good for what you want. But to answer your question, you want a smaller rear sprocket to get more top end speed.
More teeth in front = more speed
Less teeth on rear = more speed
Old Nov 4, 2004 | 01:33 AM
yea its cool thats what i meant. ill try to get a bigger one. i saw a honda nighthawk i think thats what it is, at San Fransisco today it had a big sprocket on the front and on the rear it was really small. so yea smaller on rear makes it faster.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
scottdubya83
Aug 29, 2015 04:08 PM
Dammar
Aug 26, 2015 07:12 PM
