magnum 425 relay clicking at random
Old Nov 1, 2004 | 10:07 AM
datura's Avatar
Default magnum 425 relay clicking at random
Hi, I'm having a starting problem, if I quickly turn on both keys and hit the start button it will start but if I wait I hear this relay clicking sount and it will eather start in one postion or not in the other. I blew out all my lights....oops.. is it some sort of short and where do I start looking? any help is appreciated.....
ATV in Okeechobee Florida
Old Nov 1, 2004 | 07:27 PM
ftwflh's Avatar
If you blew all the lights I bet the battry is bad .I would get a new battry,change ALL the bulbs then check the relay by shorting across it.
Old Nov 14, 2004 | 11:34 AM
datura's Avatar
I replaced the battery and solenoid(sp?) to no avail, I hear a click when the keys are turned on and it will eather start electrically or not. when I turn the key off a few seconds pass and I hear a "CLICK" after everythings off. help!!!!!
Old Nov 14, 2004 | 02:30 PM
ftwflh's Avatar
Do you by chance have a WArn winch on this?
Old Nov 15, 2004 | 02:49 PM
datura's Avatar
no I don't have a wench. I think the problem may have started when I touched jumper cable wires together. although the original owner says that it had a light blow out before. any help or direction is appreciated!!!!!!!!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Gwolf228
Feb 18, 2017 01:36 AM
kbazzy
Sep 26, 2015 11:26 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
