max rpm on a 500sp
Old Nov 3, 2004 | 12:35 AM
Bubs's Avatar
Default max rpm on a 500sp
i got a question about the max rpms on a 500 ho,my brothers got a 04.5 his max is 6200-6300,i got a 04 and mine revs to 6900 to almost 7000,anyone have any idea why this is,is his not set up right or is mine reving too high.
Old Nov 3, 2004 | 09:23 AM
ktmguy70's Avatar
Clutching will do this, if his alignment is off, It wont turn quite the RPMS because of drag.. Im assuming both are jetted the same, running the same filters, etc..
Old Nov 3, 2004 | 12:29 PM
braveops's Avatar
i sure would like to know what my 02 500ho should run and what is the max rpm it can run ?
Old Nov 3, 2004 | 02:14 PM
scramblered's Avatar
500 h.o. engine is max limit at 6800 rpm,or at 6800 the crank wear
out pretty fast,,,those are from dyno figures.
is'not not a high revving engine,you should drop some more weights on r
the primary to drop rpm to the stock max rpm output of the pipe to prevent over-revving or abuse.
Old Nov 3, 2004 | 02:19 PM
Bubs's Avatar
i havnt got a pipe on it,all i have is a k&n filter
Old Nov 3, 2004 | 10:51 PM
braveops's Avatar
hey what are u using for a tach on the 4 strokes? and how do ya hook it up?
tonythom
Aug 24, 2010 02:15 PM
gemini girl
Jul 11, 2009 02:56 PM
CHICKENman
May 10, 2000 09:23 PM
Smokinthebear
Apr 19, 2000 09:40 PM
