Air/Fuel Screw??
Old Nov 3, 2004 | 11:00 PM
abaran's Avatar
Default Air/Fuel Screw??
I'm not really experienced when it comes to carbs. I have an end cap mod and K&N filter. I need to adjust the air/fuel ratio because my plugs are black. Where is the air/fuel screw.
Forgive me for my stupid question, but I need to learn somehow.
Thanks,
Colin
Old Nov 3, 2004 | 11:09 PM
R00ST's Avatar
well if your plugs are black you will most likely need to adjust more than just the idle circuit. (although rich idle circuit can make plugs go black even if your other ciruits are ok)
what elevation/jetting are you currently running?
but to answer your question, the air fuel screw is toward the front of the carb (toward engine) recessed up in a 1/4 inch or so sized hole (its about 1/2 an inch up in there)
you turn it clockwise (IN) to lean, and then counter (out) to richen.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
