My Magnum 500 won't start after warmup
Old Nov 4, 2004 | 09:02 PM
skidmarks's Avatar
Default My Magnum 500 won't start after warmup
[img]i/expressions/face-icon-small-sad.gif[/img] My 99' Magnum 500 started acting up this week. Although it starts right up (cold start) and runs good, it will not restart if I shut it off after it is warmed up. It turns over fine but does not start. Only after letting it sit for about 15 minutes (presumably to let it cool off), will it start again. I put in a new plug but that made no difference. Is my Magnum vapor locking? Ingition coil going? Any ideas? Everthing I've check seems normal. Thanks in advance for any help!
Old Nov 4, 2004 | 09:08 PM
wgr's Avatar
wgr
Try useing the pull rope when it wont start. If compression feels low your valves need adjusting.
Old Nov 4, 2004 | 09:48 PM
ftwflh's Avatar
DITTO on the vale adjustment.They set at .006
Thanos
Jul 12, 2015 08:40 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
1000gade
May 27, 2015 12:37 PM
