no oil pressure
Old Nov 4, 2004 | 11:34 PM
force2's Avatar
Default no oil pressure
I have a oil pressure problem on my 650 praire the light keeps flashing i thought it was the oil pressure switch so i tested it and its good so i put a oil pressure gauge on it and it reads zero anybody got any ideas or experience with this ??
Old Nov 5, 2004 | 01:25 PM
Kawi650's Avatar
Oil pump gone... been there[img]i/expressions/face-icon-small-wink.gif[/img] how many hours I was at 840hrs.
Old Nov 5, 2004 | 11:16 PM
force2's Avatar
[img]i/expressions/face-icon-small-sad.gif[/img]I,ve got 163 hours on it and have been very good about changing oil and i use synthentic oil so i don,t think it was caused by abuse the dealer tells me that the pumps are bullet proof and they have never had a failure. i,m in the process now of tearing it down to replace the pump
Old Nov 6, 2004 | 06:32 PM
Kawi650's Avatar
I heard that before LOL! My dealer at the time say run it with the oil light on because it's only a senor that's it.... I say NO we are going to fix it first, the dealer goes out side and start it up and drove it in the shop.... I went blistic... I told them to leave it off.... I even walked 2 hours and took my truck and pushed it on the truck when it went because there was no way I was running my machine with the oil light on. Turns out it wasn't a senor. Also the same dealer told me the oil pump was bullet proof.... By the way there is a sensor to look at too but I believe that it's your oil pump.
Old Nov 6, 2004 | 07:53 PM
Slowdawg's Avatar
Had the same problem awhile back, it was the sensor at the bottom of the oil cooler (right side). It had came apart and blocked the return from the cooler.
Old Nov 8, 2004 | 08:08 PM
force2's Avatar
Found out the problem talked to a dealer and he called Kawi and they said it not the pump but the releif valve it either fell out or came loose they have had a couple of these in the past the way to get to it with out splitting the motor is by removeing the swing arm so i did the valve was tight so for some reason i glanced at the oil pump and the bottom of the housing is busted so no matter what dealer tells you they are bullet proof i,ll argue with them any day hope this helps someone else
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
