Warrior Backfiring and Burning Oil
Old Sep 3, 2000 | 11:39 AM
WarOf87's Avatar
What does that mean and how do I fix it? Thanks.
Old Sep 3, 2000 | 06:29 PM
hot_shoe_cv's Avatar
Usually when a 4 stroke starts burning oil it means the rings are gone allowing oil to blow by the piston, thus losing compression in the process. The back fire often is caused by the pilot jet being to lean, depending on when the backfire occurs. I think I'd address the top end problem first with new rings. Wouldn't hurt to look at your piston, cylinder walls, valves & springs while you're at it. If it's all original, some or all of the above could stand replacement as well.
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Brandon400
Sep 7, 2015 12:20 PM
