Keihin 39mm FCR or 38mm Edlebrock
Old Nov 6, 2004 | 06:30 PM
Eaglecollector's Avatar
Default Keihin 39mm FCR or 38mm Edlebrock
I also plan on going with the hot cam stage 2 which of these 2 carbs would be best for my 440 with 13:1 JE. I mostly dune ride but also hill drag a lot as well.
TIA
Old Nov 7, 2004 | 02:54 AM
cals400ex's Avatar
most people like the fcr's over the edlebrocks. however, the 41 might suite you better for dragging.
Old Nov 7, 2004 | 03:27 AM
iceracer65's Avatar
the fcr is easily the best carb out there...all of the pros use it and it comes stock on all the new 4 stroke dirt bikes that come stock with almost 50 hp...if you get your ex up that high the carb will be the least of your conserns!!
Old Nov 7, 2004 | 09:53 PM
Thats exactly what I was hoping to hear[img]i/expressions/face-icon-small-smile.gif[/img] I was wondering if the 41 would be ok or not. Thanks for the help.
Old Nov 7, 2004 | 10:15 PM
bulldogz400's Avatar
Larry-
The 41 will be a lot of top end, and would work really well for drags. I'd suggest running the FCR 40mm, which you can get for about $350 from servicehonda.com. The cheapest I've found 41's at were a couple hundred $$$ more. That's what I run on mine and you've seen me race before. Good luck!
Old Nov 8, 2004 | 02:27 AM
cals400ex's Avatar
Originally posted by: bulldogz400
Larry-
i am running the 40mm too. however, i haven't found a good way to rig up the intake boot fitting properly. i went out and bought one of those noss adaptors for the intake boot but the noss adaptor is a ways too big. it was made for the 450r. people told me it would do wonders but it isn't cheap. well it doesn't do wonders because it is too big. lol i may just boil that boot and try to make it fit.
Old Nov 8, 2004 | 07:24 PM
Thanks Dane...where on their site did you find it. I went to the aftermarket section and did a search and couldn't find a 40mm FCR. Sudco wants 585 I think it is for thier 41mm with the twist throttle and cable.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Nov 8, 2004 | 08:14 PM
On the home page, their is a link at the top that says "Parts", then go to "OEM Hard Parts", scroll down to find "2002-2004 CRF 450" (the carb comes stock on the dirt bike), then find "Carburetor".
The part # you want is... 16100-MEB-771 ...which comes to $353. Finally, find a throttle cable from a 450R, which is like $20 (also from Service Honda). The throttle assembly from your 400EX works perfectly for the cable. The total should be around $380, not too shabby if you ask me!
Oh btw- That carb is from the 2003 model, and is $20 cheaper than the 2002 or 2004. I called Honda to ask the differences and the only thing they said was different were the main and pilot jets that come in them...one was like a 170 and the other a 175 on the main...LMAO, I guess that's their way of getting an extra 20 bucks outta someone who thinks they are getting an updated carb!
Lemme know when you need some jetting specs, I should be able to give ya some help so you don't have to start off blind!
Old Nov 9, 2004 | 04:05 PM
Right on Dane!! thanks dude thats a big help and big time savings[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 9, 2004 | 11:19 PM
No problem man, glad I could help! [img]i/expressions/face-icon-small-happy.gif[/img]
slowgsxr97
Mar 18, 2022 03:40 AM
WarriorDude350
Sep 6, 2000 08:03 PM
WarriorDude350
Sep 2, 2000 02:24 AM
WarriorDude350
Sep 1, 2000 09:33 PM
