Warrior Airbox Mods.?
Old Sep 2, 2000 | 03:06 AM
WarriorDude350's Avatar
Hey there,
Just wondering what mods., if any, you guys have made to your Warrior? I have a K&N w/ Outerwear and I want a good airbox to protect it!
Thanx for your help!
'99 Warrior-----> Dynojet Powerjet Kit, Keihin PE Series 38mm carb., Banshee springs up front, K&N Powerkit w/ O/W, Armadillo Skid, White Bros. Meggalloy pipe with Supertrapp cap & more on the way!
Old Sep 3, 2000 | 04:09 PM
RayWarrior's Avatar
Hey Dude, you really don't need a better airbox for protection, you need to modify your airbox for breathing capacity. The outerwear keeps your filter pretty clean. DG makes an aluminum airbox lid for the warrior but I couldn't find it so I bought a used lid and cut it in half right behind the first three bolts since you got to have that part of the lid to hold the filter in place. Now, throttle resonse is awsome and it performs way better than I had imagined it would. The filter doesn't get real bad dirty, but I don't mud ride either. I run the good lid on it when I'm going to be in alot of sand and water though.
'99 Warrior-DG exhaust, Webb cam, Dynojet kit,
Wiseco piston, K&N filter w/outerwear
'89 TRX250R Fully Modified w/Lonestar frame 330cc kit and much more.
Old Sep 5, 2000 | 02:17 AM
Swain's Avatar
did you have to rejet after putting the holes in the lid?thanx and how many sizes
Old Sep 6, 2000 | 08:03 PM
RayWarrior's Avatar
I rejetted to a 160 main jet from dynojet, but thats what worked on my bike. The way to jet a bike is to keep going up one jet size until it cuts out at wide open throttle (WOP). Then back down one size under that jet. If it cuts out with a 160 back down to a 158 for example. All bikes are different and respond different to mods.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
JakeXBL
Sep 5, 2015 01:08 PM
