Slipping Rincon Trans
Old Nov 9, 2004 | 03:20 PM
BAH468's Avatar
Default Slipping Rincon Trans
If the temerature is cold outside the trans. on my 2004 Rincon slips badly for the first several minutes until the motor warms up. Have other people had this problem? Is it normal?
Old Nov 9, 2004 | 03:34 PM
Kawi650's Avatar
By a belt drive they don't slip when they get cold! [img]i/expressions/face-icon-small-wink.gif[/img] LOL I would take it easy until it's warmed up. I don't know it if's common but the Rincon that I had out last winter was slipping a little until it was warmed up. Bring the idle up a little for the winter.
Old Nov 9, 2004 | 03:51 PM
BAH468's Avatar
It slips badly enough that the quad won't even move for a couple minutes until it is warm.
Old Nov 9, 2004 | 05:29 PM
WISTECH's Avatar
Can you use synthetic ATF in those?
Old Nov 10, 2004 | 01:50 AM
goattrotter's Avatar
What kind of oil are you using.
But really, just let warm up and you wont have a problem.
Old Nov 10, 2004 | 09:47 PM
Duramax's Avatar
Get you some Shell Rotella T Synthetic 5-40 and you should see a difference.
Old Nov 10, 2004 | 10:29 PM
BAH468's Avatar
Thanks guys. I will try the synthetic and see if that changes things. So, you think this is normal with the Rincons?
Old Nov 10, 2004 | 10:37 PM
Gimpster's Avatar
I suggest the use of Honda's 0w-30 synthetic oil, and ask your local service dept. for a copy of service bulletins concerning proper warm up procedures for the Rincon. I believe the warm-up proceedure was sent out in the form of a service bulletin, to dealers, or in the Honda technitions copy of "The Wrench" newsletter.
----- Gimp -----
Old Nov 15, 2004 | 11:19 PM
Quad4Fun's Avatar
Haven't really noticed that on mine.
Haven't run a lot in the cold, but have ridden in the snow a few times.
Maybe it's a lot colder there than when I ride up here.
Good Luck
Old Nov 16, 2004 | 06:16 AM
rooster's Avatar
Yes, this is common to all Rincons. After a few minutes of warmup they will work like normal. They need a little while to pump the torque converter full of oil as it seeps out after sitting overnight. rooster
Jeff Roper
Feb 1, 2022 11:48 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
