rubicon tires
Old Nov 10, 2004 | 12:17 AM
den1223's Avatar
Default rubicon tires
What is the biggest tire size that can be put on a stock rubi without any lift or fender mods ?
Thanks
Old Nov 10, 2004 | 12:40 AM
maddog56's Avatar
I've had 26" mudlites on a rancher, so I'd say at least that. I think you may be able to squeeze some 27's under there with no rubbing or suspension issues depending on tread depth and tire width. A set of offset rims helps a lot as well.
Old Nov 10, 2004 | 01:57 AM
mudblaster's Avatar
my friend has 27" mudlites on his and his has a lift kit.
and i have 26" mudlites and a lift kit on mine.
even with the lift kit you wont be able to go bigger then 27s or they will rub the fenders.
the lift kit was $80 cdn so maybe 50 us dollers.
and its well worth it.
check out my page its got some pics of it with the lift kit and tires on it.
Old Nov 10, 2004 | 02:00 AM
maddog56's Avatar
Lift kits are hard on cv and other drivetrain components and are also a liability on off camber situations.
So I wouldnt be installing one unless I really, really NEEDED the clearance for tires.
Old Nov 11, 2004 | 11:24 PM
mudblaster's Avatar
my honda is no differant in the handleing department then it was stock.
actully i think its more stable then befor i put the liftkit and tires on it.
because the tires are wider and so is the wheelbase.
and i asked alot of people about the liftkit befor i bought it and the only ones that had any problems with ujoints was the guys who had irs not sra.
and ive put over a 1000 miles on it since i put it in and seems fine.
no problem with it yet.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
