05 prairie wont start in neutral
Old Nov 13, 2004 | 03:42 PM
cookerwon's Avatar
Default 05 prairie wont start in neutral
hey guys i have an 05 prairie 700 when the gear shifter is in neutral and the neutral light is on on the display it wont start, but it starts fine when you hold either brake. could the shifter be out of adjustment?, i thought if the light on the display says its in neutral it would start? any help is appreciated
Old Nov 13, 2004 | 09:55 PM
kawakasi's Avatar
Got the same prob with my 02....Just started bout a month ago
Just fixed the opposite prob...would not start unless it was in neutral.
That was the little black box under the seat just to the left of the fuel sending unit...
I think my dealer called it some kind of safety switch...replaced that and everything
was good to go till this crap started......not a big deal just bothers me....
Any ideas will be appreciated....thanx
Kasi
Old Nov 14, 2004 | 11:51 AM
Uinthas's Avatar
Just the other day I adjusted the shift linkage on my 360.. After it was done I noticed that when I put it in N the N light did not come on & would not start without the brake pullled in.. I adjusted it back slightly & now everything is fine.
Old Nov 14, 2004 | 12:58 PM
kawakasi's Avatar
Ive tried everything....absolutely will not start in any shifter position R/N/H/L unless i apply
a brake.....Doesnt matter which brake...any will do
Kasi
Old Nov 14, 2004 | 01:57 PM
deerchooper's Avatar
the neutral starter circuit relay is bad. if you look beside the cdi there is a little black box (which is on the left hand side looking from the rear of the quad).
you can try 2 things.
1. hit it with a screw driver a couple times to see if that fixes it. it has worked for me this way.
2. look inbetween the the 2 cross members of the quad, you will find one that looks exactly the same as the neutral SCR. well its the brake SCR, switch them and see if that works. if that does work then you will be able to start in neutral but not with the brakes. which will tell you that the neutral SCR is bad.
i dont know if its the same on the 360p, never seen one up close.
Old Nov 14, 2004 | 03:53 PM
kawakasi's Avatar
You the man choop
I switched them...[by the way the brake SCR is only bout a month old]
and everything worked fine...switched them back to their original places
and everything is a-ok.....that tells me it was a bad connection
thanx again
Kasi
Old Nov 14, 2004 | 05:43 PM
glad i could help you kawakasi
Mkp
Mar 28, 2020 03:50 AM
kwackermann
Jun 24, 2015 10:18 AM
Dabears1983
Jun 16, 2015 12:17 PM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
