Starting problems and tie rod ends
Old Nov 16, 2004 | 07:30 AM
Grizzz3's Avatar
Default Starting problems and tie rod ends
I have a 96 Sportsman 400 4x4. I have recently purchased a new battery and was riding the machine last night running the lights. After running it for about 20 minutes, I turned it off (and the lights). A short time later I tried to start it but it was tunring slow as if the battery was low. Any suggestions? Also my outer tie rod ends are loose and needing replaced. Which ones are the best to get? And does it matter if they have zerks? It seems alot of them do not have grease zerks.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Nov 16, 2004 | 07:50 AM
ftwflh's Avatar
Sounds like you have a bad stator.Charge your battry up and and check the voltage should be 12-13 volts.Start the motor and recheck it while reving the motor alittle and it should go up to around 14volts. On the tierod ends if you can afford it up grade to the new style but you will need all 4 along with the new hardware.The stock ones are ok but do wear out faster.
Old Nov 17, 2004 | 02:05 AM
Grizzz3's Avatar
I have been looking for the tie rod ends. What is the new style?
Old Nov 17, 2004 | 07:47 AM
ftwflh's Avatar
The new style is a heim joint and tou will need nuts bolts and washers to use them.Maybe even new tie rods.
tiresharkdbb
Sep 3, 2017 02:06 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
