how hard is it to change my clip position?
Old Nov 16, 2004 | 02:33 PM
jackass650's Avatar
Default how hard is it to change my clip position?
i am gonna mod my endcap and just curious how difficult it is to change the clip position? and what order do the washers go in from top to bottom? i have read lots of posts about guys getting the order mixed up and i have looked at my cdrom and it says nothing about the order,
Old Nov 16, 2004 | 02:53 PM
chirochris's Avatar
you may not need to touch your carb at all, put the end cap on and run it, mine didnt need it.
i dont have dyno to prove this but it runs great i did a few straight runs and also some slower rides and no bogging or anything..
just my opinion but i am no pro!
Old Nov 16, 2004 | 03:29 PM
NickDS650's Avatar
Its not so much difficult but time consuming, u need to have patience becuase your dealing with small delicate parts, like the clip itself, dont wanna lose that baby lol. I got my help from HighTower, good guy u should pm him, helped me alot and explained it very well.
Old Nov 16, 2004 | 04:51 PM
jackass650's Avatar
does anyone have a pic of the clip washer order? thanks fellers
Old Nov 16, 2004 | 07:56 PM
DuneRider650's Avatar
I ride a little here and there......
well the first time we did it on my ds it was a bit harder because we had the old screws now we got bolts on the top and it only takes a very little ammount of time to do it, its very easy and simple.
Old Nov 16, 2004 | 09:16 PM
atvaddict01's Avatar
The first time you do it take the whole slide inside and set it on
a light cloth at the table.Then reach inside and grab the flat plastic
peice with needle nose plyers and pull.Watch out for the little spring!!
When you pull it out note how everything os on th needle.After putting
changeing your clip put it back the same way.
Good luck. If i can do it anyone can.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 16, 2004 | 09:41 PM
jackass650's Avatar
ok i just wanna make sure the guy who had it before me didnt put it back together wrong that is why i was askign about the washer position thanks
Old Nov 16, 2004 | 09:54 PM
From the pointy end small metal-white plastic-clip-small metal-spring-plastic piece that holds it in
Old Nov 16, 2004 | 10:49 PM
jackass650's Avatar
ok thanks i am gonna check it in the morning attict
nachop
Feb 14, 2018 06:57 PM
cody500ho
14
Aug 14, 2015 05:03 PM
ghost civic
Jul 30, 2015 04:09 PM
TLC
Jul 25, 2015 02:24 AM
Aitch
Jul 21, 2015 09:40 PM
