MRHP CAMS
Old Nov 16, 2004 | 11:16 PM
shmee's Avatar
Default MRHP CAMS
i need to know what the specs are!!! i know that he will not tell anyone.[img]i/expressions/face-icon-small-mad.gif[/img] but if someone is planning on putting them in soon MEASURE THEM! or what are some specs on the pami ones? off hand anyone know thanks.
Old Nov 17, 2004 | 12:29 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Default MRHP CAMS
Look on
www.team-pami.com
Look under products of the DS650 and F650. Cams lift is give in mm.
Old Nov 17, 2004 | 12:37 AM
shmee's Avatar
Default MRHP CAMS
no one know hp's cams? thanks bom. what im trying to do is find out if his cams are split or not. guys with the 110's or streight 109's,,,,,,,why? how do you know that your exhaust and you intake are flowing the same????!!!! you dont right. i think the best cams out there are the a1a2 unless you have a drag pipe right?? then the 450s would work the best. right?? so what is mrhp using?? why doesnt he tell us????????????????????
Old Nov 17, 2004 | 12:52 AM
THEBOM's Avatar
Default MRHP CAMS
The 450's are too big. They need to be reworked. I'm still working on a good cut for them. I hope to have somthing by spring.
Give it up on finding out MRHP cam spec's. You could find a pot of gold easyer. ?????????
Old Nov 17, 2004 | 12:54 AM
shmee's Avatar
Default MRHP CAMS
LOL. thanks bom please let me know what you find out! your the man!!!
Old Nov 17, 2004 | 01:06 AM
CountryJoeGlass's Avatar
Default MRHP CAMS
Why not ask him (Mr.HP) if they are split? Tell him what lift & duration cams your looking for? If he doesn't have what you want than don't buy it. I have the HPR-3 cams with to stock bore & stroke, I'm going with the HPR-4 cams when I get the 730kit. Thats just me & sure others will go with a different set up. Everyone rides or races different. JMO.
Old Nov 17, 2004 | 02:35 AM
AllRedBomber's Avatar
Default MRHP CAMS
I know someone that has a "CamDoctor", if you send me the cams, i'll tell you exactly what they are. Lift, Dur/Dur@.050, L/S, Centerline, Overlap@.050, open/close #'s, everything. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 17, 2004 | 08:25 PM
shmee's Avatar
Default MRHP CAMS
joe i would like to what im buying. do you buy car and truck cams that are numbered 1 for small and 5 for big? no, everyone tells you what the specs are right.
Old Nov 17, 2004 | 09:14 PM
Sandaholic's Avatar
Default MRHP CAMS
Shmee,
You are right, everyone else does publish there cam specs. For what ever reason Eric does not want to publish his cam specs. He also asks that people who buy his cams not give out the specs. If you feel this is wrong, not right, or unconventional, the answer is easy, Don't buy his Cams!
When I purchased my cams, Eric and I talked in great length about my riding style and future mods. From there he recommended one of his numerous cams for my application. The process was not here are the specs, pick which one will suit you best.
Old Nov 17, 2004 | 09:19 PM
Sandaholic's Avatar
Default MRHP CAMS
