MRHP CAMS
Old Nov 19, 2004 | 08:06 PM
  #21
shmee's Avatar
Default MRHP CAMS
well im not looking for me im trying to sell mine, its for someone else.
Old Nov 19, 2004 | 08:21 PM
  #22
H's Avatar
H
Default MRHP CAMS
I'm looking for me. Heres my setup- woods pipe, TM45, woods cdi ,ported intake, airbox off snorkle on, 11.5-1 piston A1-A2 cams, ported head bigger valves shim under bucket. Iride mostly sand Iwant good mid and upper RPM pwer 5000-9500 what would be a good grind for that? Sorry to step on your thread Shmee.
Old Nov 19, 2004 | 08:30 PM
  #23
shmee's Avatar
Default MRHP CAMS
ya no problem[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 19, 2004 | 09:43 PM
  #24
OregonDunePatrol's Avatar
Default MRHP CAMS
H,
Since you asked me what the best cams are for your existing set up, I'd say that the cams you have are the quickest. However, you could increase your horsepower by going to a 425 lift cam, but the problem with those is that they aren't as quick. For dunes, quickness is more important than horsepower alone - I'd say keep your cams. I believe the only time you should ever consider .425 lift cams is when the piston compression is so high there simply is not enough room for them. I run the 14:1 with the .425 lift cams - they are great for flat Baja wide open racing, but they are not as good in the sand as a 12:1 piston and a combination cam like you have. Compression specs are one of the trickiest things that dealers can mess you up with. I hear of horror stories of folks that were sold XX compression piston, only to find that its not! That really messes up your performance when you based your cam choice off the incorrect piston compression.
I've run both cams (like the ones you have and the .425 lift), and for dune drags, sand dune trails - your combination is best. But for baja style riding the 14:1 and .425 lift cams are best. IMHO.
There are other things you can do to increase horsepower - turbo, fuel injection, or even increase your bore size. But those would considerably alter your existing set up. You may also want to consider sprocket size or tire size; those are things that wont alter your setup considerably.
Marky
Old Nov 20, 2004 | 05:18 PM
  #25
H's Avatar
H
Default MRHP CAMS
Thanks for the reply Marky, I have to admit I do like my cams, Just wondered if there was anything substancially better. Sounds like not . Thanks again.
Old Nov 20, 2004 | 09:39 PM
  #26
fast69's Avatar
Default MRHP CAMS
I have HP cams on stock piston thay run grate. But I did not buy them to run with stock piston.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
