Rear Brake Problem, please help!!!
Old Nov 18, 2004 | 12:18 PM
blind1's Avatar
Default Rear Brake Problem, please help!!!
Sorry to bother everyone with a bike question, but you all are the best and I figured you could help me.
I was greasing all the zircs (sp) on my KX250 and when I reached the back brake I connected the grease gun to it and filled it up. It was really hard to get it disconnected from the brake, but after I got it disconnected the rear brake stopped working. There is absolutely no pressure to the brake when I pump the brake lever. It worked great before I fiddled with it. Does anyone know what the problem could be?
Thanks a bunch for any and all help?
Old Nov 18, 2004 | 12:34 PM
WileyCoyote's Avatar
There's a zerk on your back brake? Isn't that zerk for bleeding the brake fluid? You may have just pumped grease into your brake fluid.
Old Nov 18, 2004 | 12:35 PM
blind1's Avatar
That sure doesn't sound good. How bad did I screw it up? Can I fix it?
Old Nov 18, 2004 | 12:46 PM
I beleive you normally have to loosen a nut to bleed the fluid. Without having done that, it's questionable how much grease could have been pushed in there. If any did get pushed in, I could only suggest opening the rear bleed hole, pressurizing the brake line from the handlebar, and pushing that stuff out.
Old Nov 18, 2004 | 01:27 PM
blind1's Avatar
Great, I will definitely try that when I get home. I feel like a dumb@ss on this one. Hopefully it isn't too screwed up.
Old Nov 18, 2004 | 08:46 PM
rotty's Avatar
Make sure that before you release the brake lever you close the bleeder or you will pull in a bunch of air.
AK47KID
Jul 23, 2015 09:21 PM
rcappie4
Jun 21, 2015 07:40 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
CountryMiles
Oct 25, 2000 01:03 AM
