High Rev Idle?????
Old Nov 18, 2004 | 06:38 PM
kaotik's Avatar
Default High Rev Idle?????
I recently purchased two 660 Rappys and noticed that when idling sometimes, it will stay reved high.
example:
In neutral...i rev it up and let go...engine revs up and drops back down but not all they way back to idle...still revs kinda high...
I then pull the clutch, pop it into gear, let clutch out slowly and very little and rev drops back down to idle right before clutch catches gears.
Is this normal or are my throttle cable sticky because they're new??
It will do the same thing while in gear as well if I let go of the throttle.
Old Nov 18, 2004 | 07:21 PM
1BADRAPTOR's Avatar
Might be a kinked throttle cable or you need to adjust the idle which is on the left side next to the carb...
Old Nov 18, 2004 | 07:26 PM
MasterRaptor's Avatar
Turn your handle bars left and right. If your idle picks up, then your throttle cable is likely bound or twisted with the choke cable.
Sometimes, when people jet the carbs, they leave the cables attached to the carbs. You have to turn the carb upside down to jet. People sometimes don't unwind the carbs before re-installing.
Old Nov 18, 2004 | 07:48 PM
kaotik's Avatar
But they are brand new...no mods yet so it cant be because of jetting. And it does it on both of my rappys
Old Nov 18, 2004 | 08:18 PM
1ShotScott's Avatar
it's mostlikely normal, my wolvy does it when it first starts up, until I start to ride for about 10 minutes. the reson why it goes back down when you put it in gear is because now you power is being put some where (the wheels). the wheels give the engine the restriction to go back to normal rev.the only time there would be something wrong is when you pop it in to gear and the revs don't go down. then you have to adjust your Idel screw.
Old Nov 18, 2004 | 09:03 PM
kaotik's Avatar
Thanks for the replies...
Im starting to think its normal since, like you said, it goes away when there is a load put on it and because its happening to both bikes.
Old Nov 18, 2004 | 09:28 PM
7QuadSport7's Avatar
No No No
on my quadsport thee EXACT same thing happend to me
i went to the dealer and they all laughed at me
ther should be like a little twistey thing called the IDle control
u turn it to the left an dit will idle faster turn it the right it will idle slower its real easy
look in your manual and you should find it its a black *** that u twist wit yur hand
Old Nov 18, 2004 | 09:30 PM
in other words it determines how fats yur quad idles it does it buy changing the gas mixture faster or slower
only sport quads have them
Old Nov 18, 2004 | 09:33 PM
1ShotScott's Avatar
my wolvy does I'm not sure if they consider a pure sport quad. I call it a SUQ (Sport Utility Quad)
Old Nov 18, 2004 | 11:32 PM
I don't think its normal. My Raptor never did that when it was new. I think it has something to do with the way your dealer set up your quads.
If the Idle screw on the left side of the engine doesn't lower the RPM, then the throttle cable needs adjustment.
IMO
