High Rev Idle?????
Old Nov 19, 2004 | 01:50 AM
INSeaRChOFDUNez's Avatar
Default High Rev Idle?????
to let all of you know, that high rev is normal. it revs high as a warning that its been in idle for long. if you notice you will se the reverse light blinking also. this happens on 04 an d above raptor that i knwo of. it also tends to rev high when you hit the reserve level on gas. read your owners manual and the maintenance manual i dont remember which one i read it on.
i forgot to add that if you move your quad a couple of feet idle will go back to normal again. check your temp light too and have the temp sensor tested mine would not turn the fan on and it revved when it was hot. its teh temp sensor at the botttom of the radiator.
Divergent12
Aug 19, 2023 05:26 AM
Cummins Driver
Sep 11, 2019 01:22 PM
donintennessee
Aug 19, 2015 02:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
MNatv89
Jul 7, 2015 11:36 AM
