nerf bars..help by tonight!
Old Nov 19, 2004 | 05:57 PM
jordan400's Avatar
Default nerf bars..help by tonight!
okay i wanna get dg steel nerf bars. i want the ones for the yamaha warrior and am just ganna make htem fit... do you think they would sorta match up nicely? im planning to order them tonight thanks.(i want the steel cuz there cheaper and i can just cut them and weld a plate to bolt to the frame like on the hot seat nerf bars.
Old Nov 19, 2004 | 07:06 PM
thewayout420's Avatar
im sure you can make them fit,i just finished putting on some yfz450 nerfs on my scrambler,the fit pretty good but if i was still at the stock width then they would stick out way past the tires..alot of ppl use 250r or banshee bars for the scramblers and they seem to work good..
Old Nov 19, 2004 | 07:29 PM
jordan400's Avatar
okay so you had to shorten the whole nerf bar? do you think the warrior will fit without having to shorten them? well the hell with it i got a friend downthe road with a warrior ill prob just run down there and measure it.
Old Nov 19, 2004 | 07:41 PM
i didnt have to cut the yfz bars.they are to wide for the width of a stock machine but my scrambler is 3 inches wider than stock and they are flush with the tires.warrior bars might fit perfect,i dont know?is there a website that you seen the bars on?
Old Nov 20, 2004 | 01:39 AM
jordan400's Avatar
i seen them in a dennis kirk magazine. but yeah i measured my friends out and they should fit pretty good without to much modification. ill be ordering them tommororow hopefully.
Valder
Nov 28, 2020 07:38 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bvolks
Sep 13, 2015 12:57 PM
ElementzzofStyle
Aug 29, 2015 10:45 AM
