The only plow i can get? Are chains a problem?
The chains should be ok on your driveway...if you need them..I would try to get by without the chains and only use them if you are having a big traction problem without them..I used my 2x4 Polaris Trail boss 330 to plow until I got my foreman...It worked ok and I never had chains...but I have gravel in my driveway...The biggest concern with my 2x4 and the plow was traction in reverse could sometimes be tricky..but I still got by.
PINKMOON
PINKMOON
well i have and 02 recon and i have a 48 in cycle country plow and i thought tire chains would be good wich they were but when my girl friend took it 4 a ride she got stuck and the tires were spinning well the chains blew off a deystroyed my rear fenders and cracked my drive case
