DS firing order ?
Old Nov 22, 2004 | 12:46 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default DS firing order ?
On the bomber do both sparkplugs fire at the same time or does one fire on the slap stroke ?
Old Nov 22, 2004 | 01:12 PM
Hightower's Avatar
same time. there is only one wire from the cdi, it tees and goes to both coils.
Old Nov 22, 2004 | 02:14 PM
Tpsycho's Avatar
Thanks Hightower. I was not sure if it was possible to mix up the plug wires or not.
Old Nov 22, 2004 | 04:17 PM
thebigshow's Avatar
since both wires are tee'd into the coil, would it be very noticable if one of your plugs fouled?
Old Nov 22, 2004 | 05:21 PM
Hightower's Avatar
there are two coils - one for each plug. a single ignition wire from the cdi box supplies both coils, and each coil has its own plug wire going to its plug. you can switch the plug wires and nothing will change. you can even leave one of them unplugged and not even notice it riding. two plugs makes for a more efficient and thorough burn, and perhaps a slight hp advantage may be noticable on the dyno, but two plugs are not necesary. they do offer a nice reliability advantage, like if you lose one coil or plug from a nasty water crossing or something, you're still racing.
true if one fouls and the other doesn't it probably would not be noticable, but whatever fouls one plug is bound to foul the other.
Old Nov 22, 2004 | 05:35 PM
thebigshow's Avatar
the reason i was asking was that i noticed yesterday while i was jetting my carb that one of my plug wires sets on my plug but doesnt snap on it like my other on does....interesting thought about the back up tho...
Old Nov 23, 2004 | 06:13 PM
BajaMark's Avatar
The "does not snap on" thing happened to me also. Get a new one, the wire that makes the spring has broken.
Old Nov 24, 2004 | 12:57 AM
thebigshow's Avatar
well i couldnt help myself... i went outside and tested the one plug theory...running on one plug i could deffently tell a difference in the way she idled...not much but if i had my eyes closed and u pulled a wire u could be able to tell it...but it basically ran the same. i thought i could tell a difference at first but its one of those things that u know u unplugged it, so u are looking for anything different to blame on the plugs...lol.
ultangler
Nov 30, 2024 01:35 AM
flyin-lowe
Dec 1, 2017 03:18 AM
IMLN
Sep 28, 2015 03:32 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Elkaholic
Sep 6, 2015 02:44 PM
