most power on pump gas?
Old Nov 22, 2004 | 06:44 PM
WIscrambler's Avatar
Default most power on pump gas?
Hey guys-
I'm back in the market for an ATV and can't decide if I want another DS650 or to build a 400 Scrambler. I know I want the straight line speed of the DS650, but I also love the gas-it-and-go of the Polaris. How much can be done to the 400 engine with it still running on pump gas(93 octane) What mods would I be looking at and what kind of horsepower would it be putting out? Thanks.
Old Nov 22, 2004 | 07:17 PM
Bradracer18's Avatar
I think you can be running in the upper 60's(hp) and still run on that octane........the sport would be faster than the ds, for the money. Plus they are a blast to ride once they are fast.
You'll need to get a clutch kit, new carb, clamp on filter, possibly big bore kit and wiseco piston, polish and port job, head, pipe, possibly lightened flywheel, possilby oil block off/starter eliminator, and more..........
You could call Rick Ritter and he could set you up real well........
Old Nov 22, 2004 | 08:04 PM
BeltDrive's Avatar
With the work that is done to my scrammy, it runs very good. I don't know the HP but I would say about 55 to 60 hp. I run 93 octane pump gas in it with no problems. Everyone I ride with thinks it's very fast for a 4x4. Like Bradracer18 said give Rick a call and he will answer all your questions. He is a great guy and does great work.
Ritter Cycle Racing
St. Jacob IL 62281
Phone (618) 644-3211
Fax (618) 644-3212
Old Nov 23, 2004 | 01:34 AM
1fastpolaris's Avatar
You could also do a 7mm stroker on 92...12-1 compression. Put the race pipe on and it will fly.
Old Nov 23, 2004 | 04:23 AM
jimmypsp700's Avatar
Ritter Cycle Racing
St. Jacob IL 62281
Fax (618) 644-3212
Yeah, what they said!!!
Old Nov 23, 2004 | 08:47 AM
omahapredator's Avatar
no, all the engine work i've done to my pred , i'm only i the lower 60's for hp.....and i have to run c-12 in my tank.....stay around 40-45hp and you should be fine!
Old Nov 23, 2004 | 09:44 AM
mudmaster250's Avatar
your also runnin higher compresion though, 1fastpolaris has a 7mm stroker so he knows whether or not he can run 93 octane. just depend on how your motor is set up.
Old Nov 23, 2004 | 12:22 PM
POLARISFREAK's Avatar
1fast, does your 400 stroker run on pump gas?
Old Nov 23, 2004 | 07:26 PM
My 400 runs on 110 and both of my 250s. I've seen a 7mm on pump and it runs really good.
Nondem
Feb 22, 2020 12:20 PM
mtdewmn
Jan 19, 2017 12:13 PM
house1
Aug 9, 2015 10:49 PM
momma's bike
Aug 6, 2015 09:49 AM
Mikea1978
Jul 4, 2015 12:37 PM
