Difference between 05 z250 and 05 250ex?
Old Nov 25, 2004 | 03:21 PM
FastestBlaster's Avatar
Default Difference between 05 z250 and 05 250ex?
Is there a difference between the 05 z250 and 05 250ex? if so what?
Old Nov 28, 2004 | 01:24 AM
nosliw's Avatar
SUZUKI-
Engine: 246cc, 4-stroke, single-cylinder, air-cooled, SOHC, 2-valve, TDCC
Bore Stroke: 66.0 x 72mm
Compression Ratio: 9.2:1
Fuel System: MikuniBSR29
Lubrication: Wet Sump
Ignition: Electronic iginition (CDI)
Transmission: 5-speed with reverse, automatic clutch
Final Drive: Shaft
Overall Length: 1720mm (67.7 in.)
Overall Width: 1070mm (42.1 in.)
Overall Height: 1090mm (42.9 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 230mm (9.1 in.)
Wheelbase: 1135mm (44.7 in.)
Dry Weight: 166kg (366 lbs.)
Suspension Front: Independent, double A-arm, oil damped, adjustable preload, 6.1 inches of travel
Suspension Rear: Swingarm-type, oil damped, adjustable preload 6.1 inches of travel
Brakes Front: Dual hydraulic disc
Brakes Rear: Mechanical Drum
Tires Front: AT 22 x 7-10
Tires Rear: AT 20 x 10-9
Fuel Tank Capacity: 10.6 liter (2.80 gal.)
Color: Yellow, White
HONDA-
ENGINE
Engine Type 229cc air-cooled OHV longitudinally mounted single-cylinder four-stroke
Bore and Stroke 68.5mm x 62.2mm
Carburetion 22mm piston-valve
Ignition CD with electronic advance
Starter Electric
DRIVE TRAIN
Clutch Automatic
Transmission Five-speed with reverse
Driveline Direct rear driveshaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone; 5.9-inch travel
Rear Suspension Swingarm with single shock; 5.7-inch travel
Front Brakes Dual hydraulic 174mm discs
Rear Brake Sealed mechanical drum
Front Tires 22 x 7-10 knobby
Rear Tires 22 x 10-9 knobby
DIMENSIONS
Length 68.3 inches
Width 41.8 inches
Height 42.2 inches
Wheelbase 44.3 inches
Seat Height 31.3 inches
Ground Clearance 5.9 inches
Turning Radius 9.2 feet
Dry Weight 349.0 pounds
Fuel Capacity 2.7 gallons, including 0.7-gallon reserve
OTHER
Available Colors Red, Yellow
Model ID TRX250EX
FACTORY WARRANTY INFORMATION
6 months Coverage of defects in materials and workmanship
Old Nov 28, 2004 | 10:59 PM
Vunit's Avatar
Yeah, the z250 is a upgraded version of the 250ex, bigger shocks on the Z, more cc, little bit better handleing but overall they are the same thing, can't go wrong with either one.
Old Nov 28, 2004 | 11:08 PM
yellowrider250ex's Avatar
even though the z 250 has more cc's the 250ex is faster. if u have dirt wheels look in the nov of 03 issue
Old Nov 28, 2004 | 11:15 PM
Vunit's Avatar
I believe that it is, the 250ex is an all around better machine, many mags tested them both and they all said that it was so. Also it has been around for the last few years and it has been a bets seller for honda.
Old Nov 29, 2004 | 04:15 PM
yea and you cant beat hondas reliability lol so thanxs everyone il look into the 250ex more.
Johnny Mac
Aug 15, 2019 03:13 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
fredrikrosen
Sep 28, 2015 09:58 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Steeldon
Sep 9, 2015 09:38 AM
