why is my carb bogging down??
Old Nov 26, 2004 | 07:05 PM
Ryanman01's Avatar
Default why is my carb bogging down??
hi, im looking at an atv and the guys says when you try to open it up fast it boggs down?? can anyone tell me why and is it cheap to fix?? thanks[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Nov 26, 2004 | 07:15 PM
Bear4570's Avatar
Either too lean or too rich. You need to look at the spark plug. Then again a bad plug will cause it too. Does it run ok if you don't crash the throttle wide open(crashing the throttle is not the fastest way to accelerate but no ones listening to me awyway)? Does it run flat out ok? What brand and what size rig is it? Auto or manual? Need way more information to give accurate answers.
Old Nov 26, 2004 | 07:50 PM
Ryanman01's Avatar
hi, it is a 1988 kawasaki bayou 300. the guys says that it has alot of crap in the gas tank and he says it run fine u just cant accelerate quickly
Old Nov 26, 2004 | 08:06 PM
Bear4570's Avatar
You probaly ought to hop over to the Kawasaki forum and ask this question there.
Old Nov 27, 2004 | 04:38 AM
lownrangr's Avatar
have you ever rebuilt the carb? Your jets can be obstructed, probably the high speed jet if it is'bogging' down. I'm not real familiar with the operation of atv carbs, but I have a lot of experience with two stroke carbs, which have a regulator portion containing diaphrams, etc. I tune my own carbs (triples) on my race jet ski. If this problem was with a ski, I'd say depending on how the spark plug looks, you'd either need to replace the plugs or lean it out or make it a bit more rich. And the the machine is that old, a carb would definately be rebuilt. But then again, atv carbs are different I'm sure. Hope you can get it all fixed.
Old Nov 27, 2004 | 08:25 AM
Shav0's Avatar
Your jetting is probably off, or the floats are set too low.
Old Nov 27, 2004 | 05:49 PM
kwackermann's Avatar
.. Rebuild the carb, and if it still does this then adjust the pilot air screw
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
GregM
Jul 29, 2015 09:41 PM
Sjrpp
Jul 5, 2015 09:04 PM
