banshee swing arm bolt won't drive out, help!!!!
Old Dec 7, 2004 | 12:31 AM
quadfever54's Avatar
Default banshee swing arm bolt won't drive out, help!!!!
I can't get the swing arm bolt to break lose, the nut is off and when I try to drive the bolt out it does not budge, wondering if the bushings have worn a groove that may be hanging it up. any suggestions????? please
Old Dec 7, 2004 | 03:18 AM
pendejo's Avatar
If you haven't tried already, spray a alot of WD-40 in there and let it sit for about an hour, than spray it again, get a small diameter(sp?) piece of solid steel(I used a piece of rebar) about 2 ft. long, get a big azz hammer and let 'er have it. If that doesn't work, you could try heating the outside of the "housing" and try hammering it out. These things have a tendency to be a b1tch to get out. I've seen someone have to actually cut the bolt before. When you do get it out, clean that thing up really good with some high grit sand paper, and use plenty of lube when reinstalling.
greek271
Aug 8, 2015 08:16 PM
Bell21
Jul 28, 2015 06:52 AM
skeets44
Jul 17, 2015 01:04 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
