T.O.R.S.?????????
Ok i have seen alot of topics on here about tors removal or connecting the wires.My Question is this do i cut the wires on one plug then connect them together,or do i cut the wire from both plugs and connect them to the other ones? i don't want to short anything out.Thanks for all input
Get a wiring diagram, it will make it 10x easier. You'll also need to buy idles screws and drill/tap your carbs, get a new carb top,and a throttle cable to totally remove the system, but there is a way to just unplug the wires. If you buy a kit it will tell you everything and then jetting will be alot easier also.
I have had my t.o.r.s. on my banshee malfunction to where the quad wouldnt start.They put them on there in case the throttle sticks wide open,itll kill the motor,i guess they forgot theres a kill switch and brakes and key and everything as well. Haha,safety features on a banshee.
