screwed up 650 ignition
Old Dec 11, 2004 | 08:58 PM
valholler's Avatar
Default screwed up 650 ignition
Should have stayed home today. Went hunting this morning in freezing rain and snow. Parked my 650 in a manner that allowed water to accumulate around the ignition which then froze. Had to chip ice away to get my key in the ignition. Had to use some effort to get key in and then it would not turn on. Used lighter to heat the key, warm enough to burn my fingers, still would not turn on. Finally cut the ignition wires and twisted them together to bypass ignition. Engine then cranked but would not start. Did I screw something up?
Old Dec 11, 2004 | 09:28 PM
MALAHATMAGUIVER's Avatar
Well I try my best to explain,to my best knowledge.....internally in the ignition switch is a resistor (value unknown to me)I believe the cdi needs to see this resistive value in order to let the coils work.Anti theft like those damn keys on the automobiles.So in short,bypassing the wires old school eliminated the resistor and therefore no spark...Reverse osmosis...put it back together like originally wired,thaw ignition and it should be grand!!!
note... Please solder all connections with proper heat shrink or liquid tape!!!M/M
Old Dec 11, 2004 | 09:41 PM
valholler's Avatar
Thanks for the resonse. After thawing out the switch it still won't turn on. Must have damaged something internally so it's off to my kawasaki dealer come Monday. Thanks again.
Old Dec 11, 2004 | 11:09 PM
alltoys's Avatar
If you access to methanol in a spray can use it to force the spray into the switch and try it again.
Old Dec 12, 2004 | 02:16 AM
Valholler,did you check all the fuses?
here's a link to Nyroc's web page starting problems
good luck!!! M/M
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
