WiLL tHaT rEaR sHoCk HoLd Up?
Old Dec 13, 2004 | 02:21 PM
CTracingraptor's Avatar
Default WiLL tHaT rEaR sHoCk HoLd Up?
I'm looking at buying a +2 swingarm for my raptor, probably a tucker pro, not sure though. What do you think about using the stock rear shock. I know a longer swingarm will put more force on the stock shock. What do you guys think about it? Oh yeah i wiegh 240
Old Dec 13, 2004 | 04:31 PM
homdaddy's Avatar
i run a tucker +6 0n my 740 with the stock shock all i did was tighten the spring a little i weigh 215
Old Dec 13, 2004 | 04:42 PM
RoostItUp's Avatar
I'm runnin a +4 on mine with the stock shock with no major problems. I weigh 165, I stiffened the shock all the way and it still sags a little more than I'd like in the rear but nothing bad enough to cause problems. Judging from mine, anything over +4 I would say get a new shock. At the stiffest setting it still sags an inch er two more than it should even with my low weight. Your +2 should work perfect [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 13, 2004 | 10:36 PM
so pretty much, tighten it all the way up. i like it soft though, for the whoops. how long does the stock shock last, i have over 800 hours on them.
Old Dec 13, 2004 | 11:26 PM
Raptor149's Avatar
The stock shocks are junk. Particularly the rear. I run a +1 1/4" with the stock rear shock. I have a 60' uphill that it bottoms on every time. I haven't gone to the extreme of cranking the pre-load to the max, but I doubt that will help. I'm just going to replace it this spring. Even on trails, cruising hard in the powerband in 4th, and it bottoms on washouts and sudden dips. I only weigh 185. What type of riding are you doing?
Old Dec 13, 2004 | 11:31 PM
Voodoothenoob's Avatar
good luck, I recommend that you replace...unless all you do is drag/cruise on the flats[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 14, 2004 | 01:26 PM
mostly sand is my riding, lots of duning and lots of drag racing. i dont ride the desert.
P.S. check out my link on ebay for a set of haulers for sale
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
