knocking noise in transmission
Old Dec 14, 2004 | 02:13 PM
TMUNROE's Avatar
Default knocking noise in transmission
I have a 1980 185, and their is a loud knocking noise coming from the transmission. I split the case and looked at the gears but I dont see any broken teeth, what else should I look for. Any help would be appreciated.
Old Dec 14, 2004 | 03:46 PM
pendejo's Avatar
Does it always do it, even with the clutch engaged or disengaged? Maybe the teeth are not broken but wore out so much that they aren't meshing together properly. Did you check the shift forks and drum?
Old Dec 15, 2004 | 12:01 AM
TMUNROE's Avatar
It does it the most, and really bad too in first gear, it only does it a little in neutral and the other gears. I do see a little wearing on the teeth, but I've seen that before and it never made a noise like this. It's so loud and bad that I thought it would be obviouse when I looked inside but apparentl not.
Old Dec 15, 2004 | 01:59 AM
pendejo's Avatar
Just read you're other post in the trike forum. KNOWSALOT is probably right, so do what he said.
Old Dec 15, 2004 | 08:32 AM
TRIPLELSTROKER's Avatar
Had a Yamaha dirtbike one time that started knocking as you describe. Like to have never found the problem. It was a crack in the ring gear around the clutch hub. When it would meet with the crank gear it would seperate enough to make a knock noise. This was a tiny hair line crack between the teeth on the clutch hub teeth. Several years later I had a buddy who owned a Honda Magna and it started knocking. WE tore it down and checked transmission and found nothing. After about the second tear down we found it to be the same as the Yamaha had been a few years before. It also was the clutch hub ring gear cracked.
Old Dec 18, 2004 | 11:46 PM
cezar21's Avatar
i had a 1987 125 that did that and as it turned out the gears where worn out to almost no end and it asn't worth it to rebuild it so i rode it till it droped the trany
Old Dec 19, 2004 | 03:34 PM
TMUNROE's Avatar
I stripped the whole motor down, and it was a whole gear in the bottom of the motor, and part of the mainshaft was wore down, and a busted piston ring, there is shards of metal everywhere. So far I have it all cleaned up, the new parts I need, except for gaskets, and oil rings. As soon as I get the rest of the parts I will start rebuilding everything. This is my first time doing this so I hope everything turns out right. I have the book and a buddy who is telling me what to do. Any advice on what to make sure and do would be valuable, thanks.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
