2003 650 drive clutch
Old Dec 19, 2004 | 02:18 PM
keepemopen's Avatar
Default 2003 650 drive clutch
has anyone got a link to info on replaceing the drive clutch it seems like a while back i remember reading that someone had a replacment, im tired of the engine brake problems that have been with my ride since new. thanks
Old Dec 19, 2004 | 03:22 PM
deerchooper's Avatar
COMET CLUTCH was going to make one but i havent heard anything since then. what kind of problems are you haveing?
Old Dec 19, 2004 | 07:41 PM
keepemopen's Avatar
the brake makes alot of noise, ive had problems with it ever since it was new the dealer fixed it twice or at least tried the first time it cost me 240.00 and it hasnt ever been right. i think it needs a torington thrust washer instead of the bushing but if i can find a improved version of the whole clutch assy i would go that way. right now i have disconnected it at least the motor .so i still have four wheel drive. this is all fine but now my rear clutch is making a smacking noise when it moves to shift when im in low range, on the trail and pushing snow. i cant beleave im the only one having this problem, if you can remember i would realy appricate the info thanks
Old Dec 20, 2004 | 08:40 AM
NovaKaw650's Avatar
Removing/replacing the drive clutch: Remove the belt. Remove the center bolt. Screw in the clutch puller. Crank in the puller until the clutch is pushed off. Reverse the procedure to install.
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
