250R clutch chatter
Old Sep 10, 2000 | 11:24 PM
ridzhard's Avatar
I had to cross a flash flood river and got water into the gearbox on my 88 250R. By the time I got home, the clutch had a little chatter to it when you get on it hard(taking off or slipping to get up a hill). I changed the oil and took a test ride and it still does it a little when I take off hard. If I let it out easy, no problem, but get aggressive with it and I get a little chatter. The clutch is recently replaced and I put the update into it. The oil is still a little contaminated, but before I change it, should I replace the clutch? Did the contaminated oil burn up my fiber plates? I have an 85 ATC 250R and have never had this problem and I have submarined that poor machine several times. Any help is appreciated. Thanks.
Old Sep 11, 2000 | 01:07 AM
Dill's Avatar
change the oil out again..water won't damage a clutch (unless left un cleaned for a long time)
Old Sep 11, 2000 | 01:12 AM
ridzhard's Avatar
Why do you think it did this on my 88 and never on my 85?
Old Sep 11, 2000 | 02:45 AM
86atc250r's Avatar
If the contaminated oil caused the clutch to slip enough, it could have overheated, causing "hot spots" to form on the metal plates, which can cause the "chattering" you are experiencing.
I hosed the clutch on my 86atc250r pulling a broken bike 4 miles out of the woods (broken swingarm, not fun), to this day, if I get it hot, it tends to grab on release, although it holds great...
If the oil is still contaminated, I would first get it completely cleaned before passing any judgement on the condition of the clutch. Eliminate your variables before ordering parts.
Old Sep 11, 2000 | 10:49 AM
retro's Avatar
Be sure to route your tranny breather hose up into the frame so this does not happen again.
ERIC
Old Sep 11, 2000 | 09:16 PM
87_250R's Avatar
what do you mean on routing it to the frame?
Old Sep 11, 2000 | 11:50 PM
ridzhard's Avatar
Thanks for all the help here guys, I guess I will change the oil again. When I do replace the clutch, I will opt for the whole kit rather than just the fiber plates. I gotta tear the whole machine down anyway to re-grease everything anyhow.
On a side note, has anyone installed a twist throttle and found the return spring just too light? I have a carb spring on order for an 88 cr250. If that fixex the problem, I'll post it here.
Thanks.
Old Sep 12, 2000 | 01:05 AM
retro's Avatar
By re-routing the tranny breather hose up around the frame somewhere, water will not get sucked into the hose. The transmission can suck or push out air. If the hose is routed straight down, it can pick up water if you go through deep enough water/mud. My hose goes straigh up under the gas tank. When I rebuilt my engine this spring, I found a bunch of crap in the transmission case area.
ERIC
Old Sep 12, 2000 | 03:20 PM
87_250R's Avatar
ok that is what i thought just wondered because you can not put it in the frane tube but i did not know if you were talking about the atc. thanks fore the info and mine is up high.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
