scrambler balljoint
Old Dec 22, 2004 | 09:11 PM
hotdogger's Avatar
Default scrambler balljoint
How do I remove the balljoint from my scrambler 500. I've already removed the hardware which holds it into place, but how do i get the thing outta there?
Old Dec 22, 2004 | 09:37 PM
thewayout420's Avatar
i always use a slide hammer and they come right out..
Old Dec 22, 2004 | 09:51 PM
hotdogger's Avatar
whats a slide hammer and how do you get it out?
Old Dec 22, 2004 | 10:21 PM
hotdogger's Avatar
Anyone??????????????
Old Dec 22, 2004 | 11:12 PM
BigBadScrambler's Avatar
This is what I did. Remove the hardware and plate and loosely bolt the a-arm back on the balljoint. Then, use a torch to heat up the balljoint. Be very careful of hot grease splattering. Then, use a big pry bar to pry the a-arm down and the ball joint will come right out
Old Dec 22, 2004 | 11:42 PM
hotdogger's Avatar
Thanks.I'll try that.
Old Dec 23, 2004 | 12:18 AM
If you freeze the new balljoint and spray it with some silicone lube. Then heat up the strut housing to get it to expand. It will make installation much easier. I used a big deep socket the same size as the balljoint to re-install it.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
