Pro Design Kill Switch
Old Dec 24, 2004 | 05:19 PM
sparky1698's Avatar
Default Pro Design Kill Switch
I bought a Pro design kill switch for my boys Polaris 90. The directions are as clear as mud, what is the best way to wire this in? Also what do you do with the wires from the old switch? Everybody have a good Christmas.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 24, 2004 | 05:54 PM
95wolv's Avatar
When I installed a kill switch on my son's 300ex, I just put a single to dual blade connector on the coil, hooked the pos. wire like normal, and the other blade I hooked the kill switch on,then through the switch to ground, kills it right now, and is a 5 second job to return to stock by unplugging,then plugging stock wiring back on.Don't know if your coil is the same, with plugs, you may have to splice into the wire on there.
Old Dec 24, 2004 | 11:16 PM
Scramblur50's Avatar
On our Scrqambler 50, we hooked on of the wires to ground and the other to the positive on the coil. As for the old kill switch, pull the 2 wires off of it and connct them together.
Bryce
Old Dec 24, 2004 | 11:37 PM
sparky1698's Avatar
Thanks for the info. I will give it a try Sunday . Merry Christmas and thanks again.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 25, 2004 | 12:49 AM
atvrme's Avatar
go to the coil hot wire unhook it. the wire that has a y in it hook the hot wire to it and the other side to the coil. take the blk - ground wire and gorund to the frame or coil screw. this is how i hooked up my sons on his 90cc eton and works great hopr this helps
fordfaithful21
Dec 7, 2015 05:52 PM
nick c
Sep 13, 2015 10:08 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
