Stuck Pilot jet
Old Sep 11, 2000 | 03:24 PM
alexm's Avatar
Apparently my pilot jet is clogged on the carb for my Mojave ( Keihin CVK). Bike won't idle with the choke off, and to keep it running you have to keep revving the throttle and it still runs like crap. All of the other jets are ok but I cannot get the pilot jet out. Is it made to be removed, surly it is. The slot for the screw driver is rounding out on the end of the jet so I cannot get it out. Not talking about the pilot screw, but the jet that is accessible from the bowl. What now?
Old Sep 11, 2000 | 03:43 PM
hot_shoe_cv's Avatar
I doubt that an Easyout is made in a size small enough to fit the opening but it might be worth checking on. If the slot isn't totally gone you might try saturating the jet head with carb cleaner or other solvent & allowing it to sit overnight, then with the proper size screwdriver, tapping it fairly hard with a light hammer & then try backing it out, repeating the process if necessary. If all else fails you may have to drill out the jet, being careful not to let the drill bit touch the valve seat.Last resort would be to order a new bowl from your dealer. If that is the option, I think I'd let them remove the pilot jet if it came installed. In that way they would be liable for damage if it too was frozen. Pehaps a drop of never seize on the threads of the new jet would prevent future seizing.
Old Sep 11, 2000 | 04:15 PM
Tree Farmer's Avatar
Check the exploded parts diagram in the parts catalog section of www.buykawasaki.com.
On some Keihin carburetors, the pilot jet is fixed and not meant to be replaced (ordinarily, there would be no need to replace it, as long as it can be cleaned).
Don't know about yours. Since the jet has a screwdriver slot, I'd assume it's meant to be replaceable. I'd use vise-grip pliers on the jet, or use an impact driver with a tight-fitting bit--you may even have to take a hacksaw and cut a deeper slot in the brass jet to obtain purchase. The brass jet and carb body threads are probably seized from galvanic corrosion and gasoline varnish adhesion. If you must remove the jet, find some small vise-grips or get an impact driver and a hammer; you'll be better off if you can clean it and leave it be, assuming it hasn't been boogered by overtightening the pilot screw.
Good luck.
Tree Farmer
Old Sep 11, 2000 | 05:05 PM
alexm's Avatar
It shows in the exploded view so it must be removable. However, it is up in a recess in the carb body so the only way to get to it is with a screw driver. Thinking of soaking the whole lower part of the carb body in cleaner to see if I can disolve the clog.
Old Sep 12, 2000 | 11:33 AM
alexm's Avatar
Finally got it out. A new screw driver with good edges and a few raps did the trick.
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
