CDI installed on bf750??
Old Dec 27, 2004 | 02:24 PM
bubsbf750i's Avatar
Default CDI installed on bf750??
I just installed a box on my BF and was wondering if it needed to be jetted or anything else before i run the machine..
and also a question on ticking noise when it gets warm the bike only has 13 hrs could this be a valve? it gets worse when is accelrated.
Old Dec 27, 2004 | 03:57 PM
2005BF750's Avatar
CDi box is plug and play, no need to re-jet but it might help get a little more out of the machine. Don't know about the ticking, my engine doesn't make any sounds like that. I have heard of several Brutes having an exhaust leak up where the header pipe meets the exhaust manifold, might want to check that. If you take it back to the dealer, put your old CDI box back in first, the Dyna CDI box voids your engine warranty.
Old Dec 27, 2004 | 04:26 PM
STAKK's Avatar
If you notice a miss/surge about 1/8th throttle you may want to have the dealer put the updated needle in the front carb, the ticking may be a slightly loose valve clearance, mine has a slight tick, I think as the motor gets more miles on it they should tighten up, if it gets worse have the valve clearance checked at about 500 miles.........
Old Dec 27, 2004 | 06:29 PM
bubsbf750i's Avatar
well its not and exhaust leak and its got worse def in the case in the front somewhere the dealer will get it back tomorrow and i already put back in factory cdi..
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
