Spark Plug Boots Pop Off!
Old Dec 27, 2004 | 04:56 PM
Scotia's Avatar
Default Spark Plug Boots Pop Off!
I replaced the plugs on my 2004 700 Sportsman a month ago. Since that time the spark plug boots will not stay on the plugs very well. They seem to go on properly and after a short ride they are popped up again. I am using the Champion spark plug from the dealer. Any hints on why this is happening and what I can do to solve it?
Old Dec 27, 2004 | 04:59 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
use a little grease on the inside of the boot
it will help the boot slide down over the ceramic,,,,so you dont get any upward pressure on the metal/metal contact
not sure if i just made sense
Old Dec 27, 2004 | 05:07 PM
Scotia's Avatar
Thanks for the help. I did put a squirt of dialectric grease into the boot and onto the electrode.
Old Dec 27, 2004 | 05:09 PM
Bing's Avatar
Super Quad Patrol
is it popping off because its not going on all the way?
is it the right size plug?
is the whole boot coming off or just the metal tip?
Old Dec 27, 2004 | 05:14 PM
TIC's Avatar
TIC
You didnt accidently re route the plug wire in a way that due to body flex or roll it would pull it off the plug did you?
Old Dec 27, 2004 | 05:30 PM
Scotia's Avatar
The Champion spark plugs are the same ones that I have got from the dealer before, so yes I would say they are the correct ones. The boot does seem to push onto the plug properly and quite snug. The wires are not routed in such a way to pull the boot off. Is it possible that I put the plugs in too tight and deformed the small metal washer at the base of the plug? Could this cause some type of 'blow by' from the compression of the engine and popping both boots off? Maybe I will have to replace the plugs again and take note of how tight I am putting them on. What can I use to clean the old dirty grease out of the inside of the plug boots? Would brake cleaner work or would it harm the rubber? How much dialectric grease are you supposed to put in the boot when you reinstall? Thanks.
Old Dec 27, 2004 | 05:32 PM
Bing's Avatar
Super Quad Patrol
dont worry about cleaning the grease off,,,or putting too much
it insulates,,,and keeps the boot from sticking to the ceramic
Old Dec 27, 2004 | 08:01 PM
hondabuster's Avatar
If there was compression blowby, strong enough to blow off the spark plug boot...youd know it. It would be loud and the motor would run like crap, and it wouldnt quit by reinstalling the plug cap.
When you put the plug cap on, does it take much of a tug to remove it? Sometimes, if theres too much grease, its gets very slippery, and the rubber doesnt grip very well.
Some spark plugs have that small, threaded aluminum cap, on the end of the spark plug. Some caps need that small 'nut' on the end of it, and some dont. Im not sure which yours is, but most dont use the small 'nut' even though the plug comes with it when new. When you took the old plug out, did it have that 'nut' , and does the new one? Or maybe you have the 'nut' and its not supposed to be on it.
when you figure it out...let us know what you find.
Old Dec 27, 2004 | 10:27 PM
lepper's Avatar
Sometimes the boots just go bad as well..
I have had that happen to me.. very simple to replace it unscrews from the wire, and a new once costs like 3 bucks..
dave
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
