DG5 installation instructions?
Old Dec 28, 2004 | 10:52 PM
rgramjet's Avatar
Default DG5 installation instructions?
Just got a DG5 and need some mounting/installation instructions for the Brute Force 750. Can anyone help me out?
TIA
rgrego1@aol.com
Old Dec 29, 2004 | 11:15 AM
tuffEnuf's Avatar
Visit
http://atv.dnsalias.com/ http://kod.gotdns.com/
or contact DG
TuffEnuff[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 29, 2004 | 11:43 AM
Ross650's Avatar
Try this:
1. as you look at your wiring harnesses (3) on the left hand harness locate the yellow with a red stripe on it. Tap into it with the DG5 red wire.
2. On the right hand harness locate the black with a yellow stripe wire and tap into it with the DG5 black wire.
3. In the center harness locate the pink wire. Cut it so that you have 2 ends. on the end going to the harness connect the DG5 green wire. On the other end going to the CDI connect the DG5 blue wire.
These instructions are for the Brute Force or Prairie that uses the 3 plug CDI. That should do it and you will be good to go. Good luck.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
toonces
Sep 5, 2015 01:14 PM
