TM ALKY USERS.
the jet toob that came with the kit is not drilled to .125 its a y8 and the sheet that comes with the kit says its drilled to .125, well its not. my main jet was bigger than the jet toob. not good. so i drilled it to .125 and let ya know more tomarrow.
I was just checking. I have installed both old and new style alky kits.I have even made a few of my own. The tube jet # is a 8Y this is as big as I use for alky. The jets depending on mods usualy are around 285+ or so depending on temp. The dyno even showed this size tube was right on. Like I said depending on mods. [img]i/expressions/face-icon-small-smile.gif[/img]
LOL... i was also double checking.------my bad the y8 is .125 or 1/8 inch. but the kicker is the 330 main i put in is bigger than 1/8. .125 is between 310 and 320.
I would start a little bigger. I've done the TM45 and TM48. I don't like alky under 50 degrees. It doesn't burn hot enough at 50 and below to make the power it normally does. Gas is better at these temps for riding.
