changing out 400ex timming chain help
Old Dec 31, 2004 | 04:46 AM
Cliff416ex's Avatar
Default changing out 400ex timming chain help
Does any one know if you have to split the case to change out the timming chain?
Old Dec 31, 2004 | 08:22 AM
powerslider's Avatar
No you don't have split the main cases, you have to remove the right outter cover (clutch cover).
Old Jan 1, 2005 | 10:09 AM
Ntrx250xJ's Avatar
Yup powerslider has it right. Also if ur changing your timing chain inspect the chain quider and tensioner to make sure there in good order. But yeah its just the right case and the head cover. Also a good idea to check your valve clearance and inspect the top end to see all is in good order. Also take your time to set the timing right. even if its off one tooth itll run like crap. good luck
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
yambam13
Jul 4, 2015 01:49 PM
