250X winter project
Old Jan 2, 2005 | 03:55 AM
flyinghighlm's Avatar
Default 250X winter project
I recently pulled out my old X from the garage and would like to bring it back to life. I have found that the carb is just about ruined from rust and so is the tank for that matter. I would like to know is it easier to rebuild or replace the carb. Also is there anything else that i can change on the bike to make it a little smoother of a ride and kinder on the trails. I have heard some about 400ex swaps, do they r4eally work? Remeber ebay will be my best friend, thanks for any help
Old Jan 2, 2005 | 09:50 AM
Ntrx250xJ's Avatar
I think im the perfect person to reply to your questions. As far as the carb maybe it would be best to just get a new one. i rebuilt the carb on my 250x and it took a while to get it to act right and get it dialed in good. For a new carb i would say ebay would be your best bet. Or for a lil more performance get a stock 400ex carb or the ultamite would be gettin an Edlebrock carb. There so nice. I have found aftermarket plastic tanks on ebay as well. If u can find one around 100 dollars get it quick. There expensive. I have done the 400ex shock conversion on my 250x and its so worth it. All that suspension travel is awesome. All u need to do is get the mounting bracket off of ebay. Diamond J customs is the place that makes them and sells them on ebay. Other than that youll need a set of 400 ex shocks. I got a pair off of a 02 400ex for 88 dollars. Just look around and youll find what u need. As for a rear shock i have one off an 01 raptor. I didnt put it in yet but i plan on it soon. Or you could jsut find a rear shock from a newer 300ex. Or if u had extra money to burn a works or elka rear shock would be badass. Everything youll need you should be able to find on ebay. Good luck and if u have any questions just ask. I built my X from just a frame.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 2, 2005 | 01:54 PM
With the 400ex suspension change, what all do i need to get, a-arms, spindles and hubs??? And for the carb off the 400ex, is there any kind of mod that needs to be done to it to make it fit, or is it a strait one for one swap?
Old Jan 2, 2005 | 05:59 PM
Ntrx250xJ's Avatar
Nope all u need is the bracket and shocks. If u wanted to u could also swap a 400ex front end on. But its not neccesary at all. And i believe the 400ex carb is a direct swap as well.
Old Jan 2, 2005 | 06:21 PM
Thanks for the help, what did you do with your rear axle to widin it? Will spacers do the trick and will 300ex spacers also fit?
Old Jan 2, 2005 | 08:16 PM
Ntrx250xJ's Avatar
My rear axle is aftermarket and to be honest i dont know what brand it is. LOL U could use spacers but i dont really like em. Better to save up the money for a wider axle and a nice axle carrier like the one lonestar has for the 250x/300ex.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
byronman
Sep 6, 2015 06:34 PM
