GSXR 600 in lt250r Frame??
Old Jan 4, 2005 | 05:14 PM
dks680's Avatar
Default GSXR 600 in lt250r Frame??
I am considering putting a GSXR 600 motor in my lt250r frame. I have searched the forms and found some references to this type of modification, but not in any great detail. I was wondering if anyone could tell me how extensive the frame modifications would be? Also how much will this little project cost and will I still be able to jump my quad and ride it through the whoops? Any Info will be greatly appretiated.
Old Jan 4, 2005 | 06:12 PM
86LT250RFatty's Avatar
i dont know, but that would be mean! the LT has suuuch a light frame.! what year is it? 85-86 only weighed 293lbs, 87-92 weighed 317
Old Jan 4, 2005 | 06:17 PM
dks680's Avatar
It is an 87.
Old Jan 6, 2005 | 08:45 PM
budrud's Avatar
I'm currently putting a similar engine in a lt500 frame and the welding and fab work is extensive. I'm not familar enough with the 250 to tell you how much gusseting and reinforcing you would need. First thing check the output shaft height compared to the frame end of the swingarm you can't change that and it will determine how much ground clearance you will lose and if you have to raise the spine or top bar under the tank. good luck
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
