GSXR 600 in lt250r Frame??
Old 01-04-2005 | 06:14 PM
dks680's Avatar
Default GSXR 600 in lt250r Frame??
I am considering putting a GSXR 600 motor in my lt250r frame. I have searched the forms and found some references to this type of modification, but not in any great detail. I was wondering if anyone could tell me how extensive the frame modifications would be? Also how much will this little project cost and will I still be able to jump my quad and ride it through the whoops? Any Info will be greatly appretiated.
Old 01-04-2005 | 07:12 PM
86LT250RFatty's Avatar
i dont know, but that would be mean! the LT has suuuch a light frame.! what year is it? 85-86 only weighed 293lbs, 87-92 weighed 317
Old 01-04-2005 | 07:17 PM
dks680's Avatar
It is an 87.
Old 01-06-2005 | 09:45 PM
budrud's Avatar
I'm currently putting a similar engine in a lt500 frame and the welding and fab work is extensive. I'm not familar enough with the 250 to tell you how much gusseting and reinforcing you would need. First thing check the output shaft height compared to the frame end of the swingarm you can't change that and it will determine how much ground clearance you will lose and if you have to raise the spine or top bar under the tank. good luck
Valder
11-28-2020 08:38 AM
EIF
04-20-2017 08:15 PM
scrounga
Honda Side by Sides
03-07-2016 05:17 AM
Levi Enstad
09-26-2015 09:00 AM
Halffast17
09-11-2015 03:30 PM
