Valve noise?
Old Jan 6, 2005 | 04:10 PM
NCguy84's Avatar
Default Valve noise?
I just installed a new hotcam stage 1 in my 04 400ex today, and it went in eaiser then i had anticipated. With this type of cam is there going to be alot more valve noise? Also i got the came sprocket marks lined up just like my manual said to do, and it seems like the timming is not off. What would the bike be doing it if was out of time? Any comments would be appreciated. Thanks
Old Jan 6, 2005 | 09:14 PM
drgnerth's Avatar
The stage 1 does make alot on noise. Just make sure you adjust the clearence and you' ll be just fine.
Old Jan 6, 2005 | 09:44 PM
NCguy84's Avatar
Thanks for your reply. Also how do you tell if its out of time? Im am sure mine is still in time but i just wanted to know. Thanks.
Old Jan 7, 2005 | 12:15 AM
NCguy84's Avatar
Anyone else?
Old Jan 7, 2005 | 04:05 PM
NCguy84's Avatar
I looked at the manual pics of where the cam sprocket should be with the 3 reference lines, one pointing up, and the other to even with the top of the head. But on the pic from the manual the reference line that points toward the back of the bike, is right on the head and the other one is just a hair above the head, so its not completely level with the head like the step by step instructions tell you to do. And when i rotated the motor to TDC and pulled the valve cover off my cam sprocket (before i even messed with the stock cam) was ligned up just like the pic in the manual. I am just worried that i might have got the motor out of time. Would i be able to tell if it was out of time. It seems to run fine, but there is ALOT of valve noise. Any help would be apperciated.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
