Searching AWD not working correctly, help
Old Jan 9, 2005 | 08:39 PM
RobRuf's Avatar
Default Searching AWD not working correctly
I searched and searched but I have a question regarding the AWD... First mine is a 04 Mag 4x4. The AWd is only working intermittingly in reverse only. Is this a normal sign for low or dirty hub fluid? I've just ordered a manual and every type of fluid that this thing holds (every some it doesn't) So before I get my manual I was looking at it today and this is what I was able to find. First: no broken wire to the gearcase (both small wires are attached but will check in details with an ohm meter. Second: Is the fill plug the 8mm plug on the right side (looking at the front)? If so I took it off and stuck my finger in and didn't feel any fluid other than what was on the wall, should I be able to feel a "pool" of it?
I do ride in mud and water the most, in doing this How often should I change my fluid? I've read my riders manual but it only says about oil not anything else that I found.
Thanks for any help or info,
Rob
Old Jan 10, 2005 | 10:14 PM
RobRuf's Avatar
Default Searching AWD not working correctly, help
Anyone, Am I on the right track to fix it???
Old Jan 10, 2005 | 10:21 PM
20045SP500HO's Avatar
You are on the right track ... I change my fluids all of them at every oil change. It seams a cheap way to keep my machine running in top shape.
Jmuddin284
Jan 19, 2026 07:16 AM
hugemoth
Jul 20, 2020 03:28 AM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
