connecting rod length
Old Jan 9, 2005 | 09:14 PM
flyridecr125's Avatar
Default connecting rod length
basically what does just lengthing the con rod length do for the motor. why do they say you should just move the crank pin instead of getting a longer rod.
thanks brad
Old Jan 9, 2005 | 09:38 PM
86LT250RFatty's Avatar
Correct. X2 [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 14, 2005 | 08:45 PM
110Wearwolf's Avatar
having a longer conecting rod increses compression
Old Jan 14, 2005 | 09:23 PM
Shav0's Avatar
Wrong. Your refering to two different terms, one is a stroker and the other is a longrod.
A stroker requires you to move the crank pin which gives you added CC's. There are all kinds of bennifits from this mod, but its also alot of work. A longrod crank is just a longer rod. You arn't increasing the CC's but your gaining added intake volume and decreasing wear on the cylinder and piston, resulting in longer life. Plus it gives you added torque, it's like using a longer wrench to remove a bolt. A stroker crank will give you much of the same results but requires more work, as I mentioned above.
Neither of these two will increase compression, unless you want them to. If you stroked the crank or added a longer rod the piston would hit the head so what most people do is add a spacer plate to take up the difference. By raising the cylinder you can adjust what your compression levels will be, depending on it's application or the octane fuel it will be burning.
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
