Neighbors tired of seeing me cussing in the garage
Old Jan 9, 2005 | 11:19 PM
BlazinginVirginia's Avatar
Default Neighbors tired of seeing me cussing in the garage
Ok before I throw another fit in my driveway in front of my neighbors maybe someone can help. Used 90cc 2000 Monsoon atv, bought a week ago son rode all last weekend it was great. Start it up this Saturday and ride for five minutes, full gas or idle and it was fine. After five minutes it bogs out when giving it gas. Sometimes it will start back up and only idle. If you let it sit for about ten minutes it will start back up and ride fine for about five minutes then the same thing happens. Any ideas before I lose it again in the driveway cussing and throwing stuff.
By the way, checked fuel, new oil, cleaned carb, new plug, kicked quad, threw socket wrench, shook carb, yelled at quad, kicked the dog.
Thanks Rob [img]i/expressions/face-icon-small-mad.gif[/img]
Old Jan 9, 2005 | 11:41 PM
Bluetickracing's Avatar
Have you checked the air breather. My sons quad had simular problems. The two halves of the air breather were leaking giving it to much air. Just a thought. one other thing is the float level correct. It could be getting to much gas flow at mid throttle.
Old Jan 9, 2005 | 11:55 PM
ozarkmaster's Avatar
bad gas?
Old Jan 10, 2005 | 12:03 AM
confusedbuyer's Avatar
my first thought was float.
Old Jan 10, 2005 | 01:15 AM
hondabuster's Avatar
Could be a plugged vent on the tank or the carb. If there is a drain on the bottom of the carb, open it when it dies, and see if theres any gas in the float bowl or You could put a clear gas line on it, and then you can visually see if gas stops flowing. Its pretty common on the small atvs, the air filters are crappy, and the pasageways and vent are tiny, and it doesnt take much dust and dirt, and they have troubles.
Old Jan 10, 2005 | 05:33 AM
Redrizza's Avatar
Check your float or to make sure you don't have debris in your carb bowl. Also check your air filter. It's got to be one or the other.
Old Jan 10, 2005 | 08:39 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Usually yelling at the quad or kicking the dog works for me. LMAO, thanks for the laugh this early in the am. I would check the gas cap vent or float height.
Old Jan 10, 2005 | 07:12 PM
c4igunner's Avatar
Have to agree with honda buster. Same thing happened on my Yamaha FZ 600 sportbike. Vent tube got plugged with something and it would run a few minutes and then just die out. After it set for a half hour it would start up for another 5 minutes. Incredibly frustrating. Luckily the mechanic caught it when I took it in. Would have saved me a lot of hassle had I checked it first. Jim
Old Jan 10, 2005 | 09:41 PM
laserman's Avatar
Take the carb off the bike and take the bowl off of the bottom of the carb.
1st check for dirt like the guys said
2nd turn the carb upside down and look at the float is it level?
3rd if not level put a screwdriver on the metal part on the float and geltly bend the piece until it is level.
4th reassemble and put carb back on
hope this works.. It did for my sons scrambler 90 did the same thing
Old Jan 11, 2005 | 12:25 AM
Thanks for all the advice, I am going to try it out sometime this week. Laserman answered the question before I posted it of how to check the float to see if its level. I don't know much about carbs. I'll let everyone know how it goes.
