Need advise for tire(s) for front of Scrammy
Old Jan 10, 2005 | 11:40 AM
MOJeepr's Avatar
Default Need advise for tire(s) for front of Scrammy
I either pinched or took a rock in the sidwall of my stock tires on my 04 Scrambler. I'm looking for some opinions. Should I replace it with a another, replace both with a different brand and/or size? What sizes and/or brands do you like?
Old Jan 10, 2005 | 02:20 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
it depends on your wants and needs
If the tires are fairly new you might just want to replace the one and wait for a new set
Otherwise check out Mudlites,,,,or Bearclaws.
Old Jan 10, 2005 | 03:05 PM
BubaHyde's Avatar
Did it slice the sidewall or cause an impact bulge or what?
If it is just a puncture you could probably put a tube in it.
I am very happy with my 489s, I will probably replace mine when they wear out with 489xt
Old Jan 10, 2005 | 03:51 PM
MOJeepr's Avatar
Probably should have offered they are Carlyle AT489, 23x7-10. I'm pretty sure I know when it happened, I hitting a rock with that tire pretty hard cruising down a trail. At first, I figured it poked the side. But now I think maybe it pinched the tire against the rim as there are two holes in it next to each other, but that is only a guess. No bulging, and in fact it will hold air for about 10-15 mintues.
The trails around here have a lot of rocks like that that poke out of the ground, and I was wondering if maybe a larger size tire might fare better and may leave the wheel less exposed. Just fishing for opinions. If getting another matching tire is a good idea, I can pursue that.
Old Jan 10, 2005 | 06:19 PM
BigBadScrambler's Avatar
Fill it up with air and submerze it in a tub of water. You will be able to find the leaks from the air bubbles. If it isnt bad, they jus tput some slime in the tires.
Old Jan 10, 2005 | 08:14 PM
MOJeepr's Avatar
I know the air is coming out of the holes on side, and I would be surprised if slime would fix it. A tube might work.
Old Jan 11, 2005 | 12:07 AM
BubaHyde's Avatar
From what you are describing a tube would be a good option. certaainly if the tire is like new.
Sandman2.0
Jul 21, 2015 09:03 AM
JackTheKing
Jul 14, 2015 09:09 PM
steveo612
Jul 11, 2015 08:35 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
